Re: SMOKEY H
Posted by Farmer Bob on May 14, 2001 at 19:46:44 from (208.49.9.123):
In Reply to: SMOKEY H posted by jim bub on May 14, 2001 at 19:27:57:
Jim Bub, To smoke that much I'd say a ring job is likely. While you had the pan off did you check the rods/pistons for any kind of slap in the sleeves? Could be ring gaps are out of proper alignment, worn excessively among a few other things. I'd also recommend a straight 30W oil as the heavier viscosity (than your 15w40) would help a little bit but not if it's that bad already.//FB
Post A Followup
: Re: Re: SMOKEY H
