Re: Hydraulic Pump Replacement on Farmall 560
Posted by Farmer-Gene on May 15, 2001 at 03:40:03 from (207.230.202.156):
In Reply to: Hydraulic Pump Replacement on Farmall 560 posted by Butch on May 14, 2001 at 18:50:02:
if you checked the relief valve you were where the pump is just unbolt and put on new one. Did this just happen all at once? Does it make a whineing sound? check just in front of the transmission shifter to make sure the cyl. controls aren't on single acting or somewhere in between.
Post A Followup
: Re: Re: Hydraulic Pump Replacement on Farmall 560
