Re: about to give up finding problem causing miss
Posted by Charlie on May 15, 2001 at 14:36:31 from (209.130.138.233):
In Reply to: about to give up finding problem causing miss posted by Gene on May 15, 2001 at 13:14:41:
Have you looked over the intake manifold for cracks or just loose or the gasket is bad. That is certainly an area that could cause a problem after warming up. Have you checked valve clearance and have you looked at the push rods to the valves. If one or more of them is bent it may occassionally stick causing a valve to not close. If you take them out and roll them on a flat surface any bent ones show up easily. I hope you find the problem and when you do, please let us know.
Post A Followup
: Re: Re: about to give up finding problem causing miss
