Re: Model A steering box
Posted by Vern on May 15, 2001 at 22:02:12 from (64.20.241.144):
In Reply to: Model A steering box posted by Eric on May 15, 2001 at 20:22:44:
The A's were notorious for loose steering. The problem is usually a loose arm at the bottom of the box. Try tightening that first. It isn't easy. If you disconnect the tie rods from the arm you then can turn the arm further to the right or left so you can get a socket on the nut while holding the bolt with a wrench. Good luck!
Vern
Post A Followup
: Re: Re: Model A steering box
