Re: about to give up finding problem causing miss
Posted by Bob M on May 16, 2001 at 08:31:02 from (192.232.119.194):
In Reply to: about to give up finding problem causing miss posted by Gene on May 15, 2001 at 13:14:41:
Gene - I tend to agree with the others - you've got a valve train problem. However before you start opening the motor up, suggest you stick a timing light on the motor and watch the timing. Do it both with a cold engine and again after it warms up. What you are looking is not the actual timing number, but whether or not the timing is stable. If the timing mark appears to be jumping around randomly (+ or - more than a few degrees) it indicates a wear problem in the distributor, and will cause exactly the symptoms you describe. We had a similar problem on an IHC truck (304 V8). Turned out badly worn distributor shaft/bushings was causing 30-40 deg timing variation - the timing marked was jumping all over the place. Replacing the shaft and bushings cured the problem. Note: Distributor wear will also show up on a dwell meter. A good distributor will show a steady dwell reading. But the dwell meter needle "dances" at all it says there's a problem. ...Bob M
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
