Re: Farmall 140 Bush hog
Posted by Haas on May 16, 2001 at 15:58:01 from (205.188.193.188):
In Reply to: Farmall 140 Bush hog posted by John on May 16, 2001 at 15:09:19:
If none of the hitch parts get in the way of the shaft, the offset is not enought to bother the universal joints. They actually work a little better and last longer if they have a small offset rather than running straight. You will need an overrunning clutch for the pto. If you do not have that, the inertia of the heavy bush hog blade will push the 140, because is runs off the transmission directly connected to the wheels. The overrunning clutch allows the bush hog to free wheel when you stop the tractor. I still recall the time as a boy that my Dad had to go pull the suburban neighor with 5 acres out of his pond because he could not stop the little AC tractor that had the bush hog on it.
Post A Followup
: Re: Re: Farmall 140 Bush hog
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
