Re: Clutch adjustments on Farmall M
Posted by michael Soldan on May 16, 2001 at 19:27:07 from (216.46.140.186):
In Reply to: Clutch adjustments on Farmall M posted by Lowell Davis on May 16, 2001 at 18:53:33:
Lowell, have you tried shortening the clutch rod from the pedal to the shaft. You will get your adjustment in free play there. Just remove the pin and turn the end of the shaft in untill you get the desired free play on the pedal. Other than that I 'm not sure what I would do next. good Luck from Mike in Exeter Ontario
Post A Followup
: Re: Re: Clutch adjustments on Farmall M
