Re: Clutch adjustments on Farmall M
Posted by Haas on May 16, 2001 at 19:46:40 from (152.163.201.179):
In Reply to: Clutch adjustments on Farmall M posted by Lowell Davis on May 16, 2001 at 18:53:33:
The clearance adjustment at the fingers is separate from the free play adjustment. As Michael says, after you set the finger clearance, you need to adjust the free play on the rod outside the clutch housing.
Post A Followup
: Re: Re: Clutch adjustments on Farmall M
