Re: What to do about paint job
Posted by bg on May 17, 2001 at 06:08:16 from (207.42.55.135):
In Reply to: What to do about paint job posted by Billy P on May 16, 2001 at 18:34:18:
Use the reducer rated for the correct average temperature at the time you're spraying. Thin the paint to the correct viscosity. NAPA should have a chart of mixing ratios for paint/reducer/hardener. You can also get a viscometer to see if it's the right consistency. Use hardener at the correct rate and use a decent spray gun at correct air pressure, A few trial strokes on cardboard or a piece of sheet metal will give you an idea about spray pattern, mix, coverage and body.
As far as the stuff already painted: sand it, sand it, sand it. The final coat will only be as good as the base you're working with. Make sure there's no oil or dust on the surface.
Post A Followup
: Re: Re: What to do about paint job
