Re: Re: Re: Re: Re: Re: CUB 154 POWER LOSS
Posted by MIKE JOHNSON on May 17, 2001 at 13:47:43 from (204.155.56.28):
In Reply to: Re: Re: Re: Re: Re: CUB 154 POWER LOSS posted by Dave Powers on May 17, 2001 at 12:12:02:
Dave,
I appreciate any information you may find. I suspect adjusting the govenor will help. Thanks for the info on the valves. Now that I have completed the rebuild, I don't think the valve springs needed to be replaced. My compression is 90-95 lbs. per cyl. I will also recheck the point gap, and adjust timing to see if it will help. Thanks again for the input.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: CUB 154 POWER LOSS
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
