Re: 1468 exhaust
Posted by Les Repair on May 17, 2001 at 17:39:55 from (206.28.174.43):
In Reply to: 1468 exhaust posted by MAGNUM on May 17, 2001 at 09:04:22:
I'ved got some M&W parts laying around. Is there a casting number on the elbow? Some of these castings were used on other kits.
Post A Followup
: Re: Re: 1468 exhaust
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
