Re: M steering wobbly
Posted by Bob M on May 18, 2001 at 04:27:15 from (192.232.119.194):
In Reply to: M steering wobbly posted by Dick Davis on May 18, 2001 at 04:06:11:
Dick - Unlikely the culprit is the Charlynn unit. Rather it's a combination of worn steering shaft U-joint, worn worm and sector gear, worn or busted worm gear support ball bearing, worn bushings supporting the upper bolster pivot shaft (especially the upper one), and in the case of a WFE, worn tie rod ends/king pin bushings. Also loose front wheel bearings can cause shimmy at high speed. What you need to do is find out how much slack exists in each component, then go thru and renew them one at a time beginning with one with the most play. Ideally the steering wheel should have less than about 3/4" of free play at the rim. I have the same problem with my (non-power steered) Super H. Currently in the process of replacing worn pivot shaft bushings and a missing thrust bearing spacer. Punch below for pix of progress so far. Post a photo of your AC combine if you can - it sounds pretty slick! ...Bob M
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
