Model A steering arm
Posted by Eric on May 18, 2001 at 10:30:42 from (216.167.166.14):
I posted a message a few days ago about the loose steering on my A. Sure enough just like you guys said there is play between the shaft and the steering arm underneath the box. Unfortunately the bolt is already all the way tight on the thing so either the shaft or the arm or both must be pretty worn. It looks like I'll have to take the whole steering box off to replace it. Does anyone know if I can fix those parts or where I might find a good one?
Post A Followup
: Re: Model A steering arm
