Farmall Tractors Discussion Board
Re: Oil pressure to cyl head
Posted by Jim Smith Ft wayne on February 12, 1999 at 13:00:41:
In Reply to: Oil pressure to cyl head posted by Stan(VA). on February 12, 1999 at 10:05:25:
Something is not right. If I run mine with valve cover off I get oil right away running all over everything. Within a few seconds I have oil running out of rocker arm assembly. You better
keep looking.
Just my thoughts
Jim
Post a Followup
: Re: Re: Oil pressure to cyl head
