Re: 154 Lo Boy
Posted by ange on May 20, 2001 at 19:21:23 from (65.227.111.72):
In Reply to: 154 Lo Boy posted by Burlon E. Alexander on May 20, 2001 at 16:19:30:
Burlon, I have a 154 that just started leaking myself. I also have arod knocking so I will have to remove the engine for a rebuild. I dont know about just the seal. Also check this site under parts suppliers should be able to find whatever you need there. None of the starter generators Ive seen turn the engine very fast including cub lawn mowers good luck . ange from Ohio
Post A Followup
: Re: Re: 154 Lo Boy
