Re: 154 Lo Boy
Posted by mel on May 21, 2001 at 04:50:01 from (198.26.123.36):
In Reply to: 154 Lo Boy posted by Burlon E. Alexander on May 20, 2001 at 16:19:30:
It is not to difficult a job to replace the seal. It just takes a little patience. First you must take out the drive shaft. Then you take the flywheel off and it will come out of the chassis if you wiggle it right. The rear seal cover plate comes off with a few bolts. Then new seal and slip it on and you have it. Make sure you use some permatex copper gasket sealer. If you don't have a manual buy that before you try this.
Post A Followup
: Re: Re: 154 Lo Boy
