Re: 57' cub, Losses hydrolics ?????
Posted by Bama Red on May 21, 2001 at 06:44:31 from (206.166.230.5):
In Reply to: 57' cub, Losses hydrolics ????? posted by James on May 20, 2001 at 19:20:34:
What are you using for fluid? If you're using a detergent oil, it is getting agitated after some use, causing it to froth and generate air in the fluid. This could cause your loss of hydraulic pressure.
Post A Followup
: Re: Re: 57' cub, Losses hydrolics ?????
