Re: Re: Super H steering rebuild
Posted by Bob M on May 21, 2001 at 08:05:59 from (192.232.119.194):
In Reply to: Re: Super H steering rebuild posted by Bob in Southwest Iowa on May 20, 2001 at 19:25:58:
Bob - Hardest part of the whole job was getting the sector gear off the top of the pivot shaft. It's on a tapered spline - took many hits from a 4# hammer before it finally let go. (Used a piece of 1/4" copper bus bar on the end to protect the threads....)
The other problem was getting the new seal into place beneath the gearbox. Not enough room to get a hand in there to get the seal aligned and started - wound up turning a "tool" out of maple dowel to get the seal started.
All things considered it was not a terribly difficult job - and the end results were well worth the effort!! ...Bob M
Post A Followup
: Re: Re: Re: Super H steering rebuild
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
