Re: Re: Re: Re: Super H steering rebuild
Posted by Bob M - one more thing... on May 21, 2001 at 10:47:01 from (192.232.119.194):
In Reply to: Re: Re: Re: Super H steering rebuild posted by Farmall Paul on May 21, 2001 at 09:48:32:
Hey Paul - One more thing I forgot to mention: When I got the pivot shaft out I found it's upper bearing surface was worn such it's OD was about 0.015" less than the ID of the new bushing - ie. the pivot shaft running in the new bushing would have had some slop - though still much less than the old bushing. So what I did was open the slot in the new bushing by about 40 thousandths. Then when I pushed it into the bolster I stuck a piece of 0.015" brass shim whose width was 1/2 the circumference of the bushing between the bushing and it's bore in the bolster. This compensated perfectly for the wear to the pivot shaft bearing surface - fit was snug but still free.
Regarding wear on the sector gear teeth, seems to me the smaller Farmalls (Cub, A, C?) use a whole worm wheel - not just a sector gear. So when the worm gear gets worn on one side you simply remove it, rotate it 180 degrees and put it back in. Effectively it becomes a new gear. Would have been nice if the H's and M's were built this way!
Post A Followup
: Re: Re: Re: Re: Re: Super H steering rebuild
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
