Re: wow, that was close
Posted by The Red on May 21, 2001 at 12:18:38 from (206.246.187.2):
In Reply to: wow, that was close posted by p on May 21, 2001 at 12:09:50:
Phil when you get Cubbie put back together and running, make sure you get that oil analyzed to make sure you are not getting coolant in the oil. Hopefully the bore and the sleeve installation will do the trick. On the H, if the cylinder wall is cracked, inserting a sleeve does no good. Coolant will still get into the oil dribbling down between the outer sleeve wall and the cylinder wall from the crack.
Post A Followup
: Re: Re: wow, that was close
