Re: hard to start H
Posted by KURT on May 21, 2001 at 13:42:35 from (209.244.91.68):
In Reply to: hard to start H posted by Nick,Hard to start in KY on May 21, 2001 at 10:03:58:
I also have an H and what I do is after
every 3 hours or so of running the tractor
I remove the spark plugs and use a small wire
brush to remove the carbon build up then
clean off with gasoline. Then it fires up
with a couple trys. Has worked 4 times now.
Yes you will need the choke on when starting
then after the engine runs for 4 seconds or
so then push the choke in and
adjust accordingly.
Post A Followup
: Re: Re: hard to start H
