Re: farmall starter problem
Posted by gene b on May 21, 2001 at 19:19:11 from (63.15.137.120):
In Reply to: farmall starter problem posted by jaw on May 21, 2001 at 17:05:36:
sounds like the ring gear on the flywheel is bad better get under the tractor and turn it over and look at the teeth on the flywheel they must be awfull there is no shimming or so do you have the right starter and a good set of cables what are you running for a battery ect
Post A Followup
: Re: Re: farmall starter problem
