Re: Narrow front end
Posted by gene b on May 21, 2001 at 19:52:18 from (63.15.137.120):
In Reply to: Narrow front end posted by Okla.-Muleman on May 21, 2001 at 18:11:29:
you can put a narrow front on an A or SA the super A had a hyd system the pump mounts on the block below the mag and tubes ran up under the gas tank to a rockshaft system had two levers by the throttle area to operate the rockshafts
Post A Followup
: Re: Re: Narrow front end
