Re: 49 H shifting forks
Posted by S-E Michigan Part Timer on May 22, 2001 at 00:11:37 from (216.234.100.50):
In Reply to: 49 H shifting forks posted by pharmal on May 21, 2001 at 11:08:55:
If I recall on my M.. I turned the platform upside down to work on the forks easier. Then I used a dab of grease to hold the ball to the spring, and the spring inside the socket while I lowered and fastened the forks. Hope this helps. It's been close to 10 years and I only had to replace the 4th/5th gear fork.
Post A Followup
: Re: Re: 49 H shifting forks
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
