Re: engine trouble???
Posted by Jim on May 22, 2001 at 08:01:13 from (198.247.178.208):
In Reply to: engine trouble??? posted by SMTA Man on May 21, 2001 at 20:29:03:
I have been down this road so many times on tractors with live hydraulic pumps. The cam gear's center breaks out or the nut comes loose and / or the keyway wears out. and slows the cam timing and bleeds off the compression. My advice is to pull the hydraulic pump and see if the cam gear is loose.
Post A Followup
: Re: Re: engine trouble???
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
