Re: Hydrolic Cylinder stuck pushed in - any advice?
Posted by ED-Ga on May 22, 2001 at 13:58:05 from (209.214.66.208):
In Reply to: Hydrolic Cylinder stuck pushed in - any advice? posted by Pete in PA on May 22, 2001 at 06:51:19:
Pete you probably don't have enough pressure to do the unsticking. The tractor system only produces 750-800 psi which isn't much.
More pressure is needed and if you don't have another pressure source on a later tractor with a 2000 psi system try the grease gun method. Just go to plumbing supply store and find enough pipe fitting adapters to install a grease zert fitting in the cylinder(or you may find large enough zert to screw in) and pump away with your handy grease gun. I would bet on it working if the seal is still good. Let us know! One more suggestion is heating piston end of cylinder while pressure is applied.
Post A Followup
: Re: Re: Hydrolic Cylinder stuck pushed in - any advice?
