Re: Re: Re: Keyed shafts to splined shaft?
Posted by Denny Frisk on May 22, 2001 at 14:41:36 from (12.4.181.2):
In Reply to: Re: Re: Keyed shafts to splined shaft? posted by The Red on May 22, 2001 at 11:00:08:
The Top shaft is splined in both the H and the M. The bottom shaft that drives the Lift-All and PTO, has the gears Keyed to the shaft on the H and the gears SPLINED to the shaft on the M. I think the Hubs forged into the gears are even oblong on the H because of this. Never had my Super H apart that far except when I pulled the Belt Pulley off it. I was more interested in getting it back together, and even that was 20 yrs ago!
Post A Followup
: Re: Re: Re: Re: Keyed shafts to splined shaft?
