Re: 40 rear tires for F-12
Posted by MikeH-Tx on May 22, 2001 at 16:53:53 from (208.2.106.100):
In Reply to: 40 rear tires for F-12 posted by farmsc on May 22, 2001 at 14:05:11:
If the price of 40in tires bothers you a little, there are a couple of alternatives.
I found a set of 38in rims made from cut off 40in welded onto a modern rim. Works great with local tractor tires.
Others have used Farmall H or C rims with modern tires (38in and 36in). The rims don't technically fit, as the axle size is 1/8in too small, but persuasion has resulted in success.
The tractor sits a little low in the rear, but only 1 inch for 38 and isn't noticable. With 36, it would sit 2 inches low and might be getting easy to see.
I got my rims with an ad on YT's classifieds.
Post A Followup
: Re: Re: 40 rear tires for F-12
