Re: Farmall C 2 bottom 1 pt hitch plow Junk?
Posted by gene bender on March 14, 2009 at 17:52:59 from (67.55.226.145):
In Reply to: Farmall C 2 bottom 1 pt hitch plow Junk? posted by John_PA on March 14, 2009 at 11:14:52:
You must not have it mounted correct as i had one like that and it worked just fine. You are correct the other rockshaft sets the tilt of the point to plow either deep or shallow. I would get an owners manual so you would then know how to set and operate it. What is your furrow wheel of the tractor set from where the front bottom cuts remember you onle have 14in from the furrow to where the point will cut when the plow is lowered. That wheel must be set correct.
