Re: Re: Re: Re: Re: engine trouble???
Posted by jakee on May 22, 2001 at 18:23:39 from (64.12.102.46):
In Reply to: Re: Re: Re: Re: engine trouble??? posted by The Red on May 22, 2001 at 06:48:31:
do not worry about the narrow valve seats, on hi dollor motors like in racing they are very thin , it will help it flow better.i think with a deegre wheel and a dile indicator you will find out if the cam has retarted it self by coming loose. i have seen them wen the key-way becomes longated ,wen you deegree in a cam like in totla power you some times only of - set the key way by .010 to .015 deegres.
Post A Followup
: Re: Re: Re: Re: Re: Re: engine trouble???
