Re: about to give up - - -engine
Posted by Dave G on May 22, 2001 at 19:15:31 from (158.252.165.43):
In Reply to: about to give up - - -engine posted by Gene on May 22, 2001 at 14:46:55:
Another thing to check - if it is 12V neg ground make sure the points are connected to the Neg terminal on the coil. If it is not the voltage to the plugs won't be as high.
Post A Followup
: Re: Re: about to give up - - -engine
