Re: Hot Super A
Posted by gene b on May 22, 2001 at 20:00:10 from (63.25.166.109):
In Reply to: Hot Super A posted by Wesley on May 22, 2001 at 19:28:01:
what temp does it run put a cooking therm in the radiator cap opening only takes a bit with one of those batt powered therms should run around 160-170 when good and warm your block maybe plugged with junk at the area around the bottom of the sleeves there are passages for the water to flow to the radiator not uncommon to see a lot of junk in this area have torn down three since JAN unreal what you find easiest way to correct is a water pump not hard to do and is a quick fix
Post A Followup
: Re: Re: Hot Super A
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
