Re: Smta aux. hydraulics
Posted by rich on May 22, 2001 at 20:14:08 from (206.9.239.130):
In Reply to: Smta aux. hydraulics posted by Mikek on May 22, 2001 at 18:45:00:
If you are talking about the IHC auxilary valve from an M to a Super M TA yes it is the same valve the lines going from the pump to the reservior are cut (or better new lines are used.)at the valve which is mounted near front end of the gas tank the pedestal may hav to be fabricated .The M pedistal drained the fluid back to the belly pump while the Super M valve returns to the larger hose which is cut and T'd . the upper bracket fits onto the gas tank mounting like the M . I hope the valve is still in good shape because there was no filter in the M system nor in the SMTA system . the pressure line is the smaller hose and is T ed into the pressure part of the valve the return line is then t'd into the return line of the valve. You will need to lock the original valve in the up position to make the aux valve work and lock the aux valve in the up or down positon to make the original valve work. If you just want hydraulic power, and not restoration to original,use a greesen valve or a cross valve with a 1000 psi relief in it and put it into the pressure line the oil then goes through the aux valve to the resivour and then the return line goes to the pump and not to the aux valve like the IHC valve . It is simpler then the original valve and can be used simaltainiously. also you can put a double valve in between.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
