Re: about to give up - - -engine
Posted by Kurt on May 23, 2001 at 03:57:27 from (204.233.241.118):
In Reply to: about to give up - - -engine posted by Gene on May 22, 2001 at 14:46:55:
Valve lash would have to be out A LOT to make it miss. Too tight of lash is worst than too loose. Set them cool say at .030, you will be ok. You must have a carb problem. When the engine is cool it can handle more fuel but when it warms it should be metered less. You may be getting too much fuel causing plugs to foul. This is my guess. Good luck.
Post A Followup
: Re: Re: about to give up - - -engine
