outer axle seal leak - help?
Posted by GSS on May 23, 2001 at 07:13:41 from (208.198.216.84):
The outer axle seal on my IH656 is still leaking. I tried buying the "o-ring" that goes behind the large washer and nut in the center on the wheel hub, but was told that it was discontinued. The dealer said that gasket maker should do the job. I cleaned everything really well and made a few separate beads of the gasket maker on the washer. After leaving it set up a bit, I put everything back together. The next time I ran it, it was like I never fixed it. Probably lost about 1 gallon of hydro fluid overnight!
Anyone ever have to fix this kinda thing? Any suggestions?
Thanks.
- Gerald
Post A Followup
: Re: outer axle seal leak - help?
