Re: about to give up - - -engine
Posted by George Willer on May 23, 2001 at 07:44:18 from (64.254.131.85):
In Reply to: about to give up - - -engine posted by Gene on May 22, 2001 at 14:46:55:
Gene, You have had many good responses, but none have commented on the importance of correct valve clearance. (some have even suggested the opposite) You don't seem confident yours are right. Spend a little time there. The proper clearance has an effect on valve TIMING! If the clearance is too much...the valve will start to open later, and will close earlier, therefore it IS important. I'm unfamiliar with your tractor, but it should use the same procedure as other 4 cylinder tractors (if it is a 4 cyl). With #1 piston on TDC on the compression stroke, adjust valves 123&5. Rotate the engine 180 degrees and adjust valves 467&8...valves numbered from front to rear. By doing it this way, you can be sure the follower is opposite to the lobe on the cam. Just to eliminate the possibility of sticking valves, lubricate the stems with your favorite magic potion while you are there. George Willer
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
