Re: Re: about to give up - - -engine
Posted by Gene on May 23, 2001 at 10:54:43 from (205.188.192.151):
In Reply to: Re: about to give up - - -engine posted by wrenchman on May 23, 2001 at 01:49:52:
Wrenchman:
I ran into this before and someone said "no problem", but wanted to run it by you. When I put a volt meter on the battery, it reads about 12.85 volts. When I turn on the switch and check the lead coming to the coil, the voltage is about 7.64 volts. What drops the voltage going to the coil? Or, is this THE problem symptom?. Thanks.
Post A Followup
: Re: Re: Re: about to give up - - -engine
