Farmall Tractors Discussion Board
Re: Is It a Super MDTA?
Posted by Harold H on February 13, 1999 at 06:29:26:
In Reply to: Is It a Super MDTA? posted by TMAC on February 12, 1999 at 19:42:07:
Your tractor should have; live hydraulics, disc brakes, live pto, and holes cast and drilled on the rear sides of the rear end like 400's and later tractors where later two point hitch mounted. All of that makes it a Series III Super MTA with or without TA. Somebody gave you wrong information on it being a 44 model. If it was a 44 model it would have; transmission driven pto, non live belly hydraulic pump, and band brakes.
Harold H
Post a Followup
: Re: Re: Is It a Super MDTA?
