Re: WIDE FRONT END FOR H FARMALL 1941
Posted by Red Rider on May 24, 2001 at 20:38:08 from (63.11.248.216):
In Reply to: WIDE FRONT END FOR H FARMALL 1941 posted by VINCE on May 24, 2001 at 14:03:02:
Vince, I-H wide fronts for M through 806 will fit your H. The only difference is the stay rod brack that bolts to the Frame to the rear of the front axle. There pretty easy to build or have a machine shop built one for you. There were a lot more wide fronts on 560 through 806 that on H's. Plus If you find a wide front off a 560 through 806 the spindles are a little heavier. There not cheap, out here in Washington I had to pay 750.00 without the rims and had to built a stay rod bracket for my 300 Farmall.
Post A Followup
: Re: Re: WIDE FRONT END FOR H FARMALL 1941
