Re: How to check oil level on transmission, torque PTO
Posted by Jon on May 25, 2001 at 10:04:07 from (209.172.217.146):
In Reply to: How to check oil level on transmission, torque PTO posted by Goosecreek on May 25, 2001 at 09:24:49:
Use Hy-Trans in tranny/TA as well as PTO. There is a plug just forward of the clutch pedal and when oil starts to run out of it, your tranny is full. There is also a plug on the same side that is in the TA housing,and you should get a little oil running out of it also. The TA and tranny are connected and take about 13gal to fill. On the PTO there is 2 plugs on the left side, when oil runs out the top plug, it is full.
Post A Followup
: Re: Re: How to check oil level on transmission, torque PTO
