Re: 560 stuck in 4th or 5th gear
Posted by Charlie on May 26, 2001 at 08:26:27 from (209.130.137.200):
In Reply to: 560 stuck in 4th or 5th gear posted by Jeff on May 25, 2001 at 18:04:28:
The Farmalls with transmissions similar to the H and M were well known for what has happened to you. A previous post mentions welding onto the end of the shifter. The other place that has problems is the pin the shifter lever rides on. Both my H and M has had the pin drilled out and a bolt put in its place. I've never had shifting problems with either.
Post A Followup
: Re: Re: 560 stuck in 4th or 5th gear
