Farmall Tractors Discussion Board
Re: IH 300 has leaky axle seal
Posted by RickB. on February 13, 1999 at 14:56:36:
In Reply to: IH 300 has leaky axle seal posted by Bartman on February 13, 1999 at 09:15:20:
Kurt & Mark are describing a Farmall 300 (rowcrop). Shawn is describing the International (utility) version. Be careful with the wheel assembly, it can weigh over 1000lb if loaded with calcium, and wheel weights. Check the outer axle bearing by watching the axle shaft as weight is taken off the wheel with a jack. You should see no vertical movement of the shaft in relation to the axle housing.
Post a Followup
: Re: Re: IH 300 has leaky axle seal
