Re: Re: Stuck C
Posted by Moose on May 26, 2001 at 14:52:25 from (12.78.117.2):
In Reply to: Re: Stuck C posted by The Red on May 26, 2001 at 10:58:57:
Thanks for the contact information. I'll probably wait until after the Holiday weekend to call him. In the meantime, I've pushed out the bad sleeve and was able to drive the piston out the bottom. Piston seems fine; however, the sleeve is deeply pitted and in my mind, needs replacing.Hopefully, your contact can fix me up with a set of rings and a sleeve. The other three cylinders are loose and I should be able to get her running for the neighbor with just the cost of gaskets and the sleeve. Thanx again!
Post A Followup
: Re: Re: Re: Stuck C
