Re: Should I replace this clutch??
Posted by CNKS on March 14, 2009 at 18:15:59 from (216.144.104.128):
In Reply to: Should I replace this clutch?? posted by Butch WI on March 14, 2009 at 13:58:44:
The fingers appear to be in the correct position. But the picture doesn't mean much. The clutch adjusment is supposed to be done with the linkage, not the fingers, although it could be done that way. The disk, pressure plate, pilot and release bearing are available from Steel Wheel Ranch for $239 minus a $24 core charge. You have it split, might as well replace it. Do not bolt the rebuilt clutch on the flywheel as it is now before installation. Hang the disk and flywheel on their respective shafts, put the tractor together, then install the bolts and tighten. Unless you have the proper tool, it is near impossible to line up the pto and clutch shafts by eye. I did order a tool from this site, however it was plastic, and I was not sure it was correct, so I didn't use it.
This post was edited by CNKS at 18:23:22 03/14/09.
