Re: Converting to 12 volt system?
Posted by Little Bubba on May 27, 2001 at 00:46:55 from (208.136.78.15):
In Reply to: Converting to 12 volt system? posted by Dave Westlund on May 26, 2001 at 18:23:44:
Dave,
Try the link that I attached at the bottom of this message. You may find a suitable system that will work for your tractor's needs.
It display's serval different methods of hooking up the electrical / charging system. You may have to open each picture and look for the one that may help you. If you find one that will fit your needs, scroll down towards the bottom of the picture and increase it to "full size", then you can print it out to check things by. I would recommend coping all pictures and keeping them with your tractor manuals for future use if needed.
Good luck.
"Little Bubba"
Post A Followup
: Re: Re: Converting to 12 volt system?
