Re: Re: H with a 3 point
Posted by Ron on May 27, 2001 at 06:33:24 from (216.93.100.168):
In Reply to: Re: H with a 3 point posted by Jim on May 26, 2001 at 18:02:31:
I have a 3pt on a 42 H. I use chains hooked to tracter by the third member to brackets I made that hook to each arm on 3pt. I adj the lenght of chain to the dept I want on the particular emplement I'm using. I plow, cultivate, with it. Not as good as my newer tractors with depth control but will work ok. You were wise in buying the heaver sag. three point too. I've bent my lighter unit a couple of times plowing.
Post A Followup
: Re: Re: Re: H with a 3 point
