Re: Re: H with a 3 point
Posted by Joe on May 27, 2001 at 08:36:50 from (216.239.164.65):
In Reply to: Re: H with a 3 point posted by Jim on May 26, 2001 at 18:02:31:
Jim
The saginaw use four bolts that go around the axel
same as the original drawbar. The belly pump works
fine with plenty of power and hold the woods brush
hog overnight without lowering. The hydraulic
lines go from each cylinder to a tee and then to
the left front outlet from the belly pump.I am using the regular belly pump control that came
on the H in 1948. Good luck
Joe
Post A Followup
: Re: Re: Re: H with a 3 point
