Re: 400 won't start
Posted by The Red on May 27, 2001 at 09:08:30 from (12.75.197.96):
In Reply to: 400 won't start posted by Steve on May 27, 2001 at 08:28:40:
Steve my starting technique on Hs and Ms with a cold engine is to crank with full choke about 3 turns, then crank with no choke. Sounds like you are flooding.
Does the 400 have a 12 volt coil or a 6 volt with a resistor in the line? I am not familiar.
Post A Followup
: Re: Re: 400 won't start
