Ifffff that is the original Chicago Rawhide seal you are in for a struggle. Those seals are really built tuff and after being in there for 70+ years they are tuff to get out. If it's a thin metal replacement seal you should be able to drill 2 or 3 holes and put sheet metal screws in the holes then just pry the old seal out. I can't tell from your picture but it sure looks like the old, original seal.
For the old original seals I have had to remove the pulley assembly. You then have to pull the gear off the shaft as the shaft comes out towards the rear. Pulling that big gear is really hard as it is on a non tapered shaft so it will come off hard the whole way. A little heat, some penetrating oil and a lot of patience is required. In the end you may break the gear as the hub is not a solid piece, it has holes in it so it is weak. You can then drive the old seal out towards the rear.
Upload one or more videos to your post. Photo and video filesizes should be less than 8MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
