Farmall Tractors Discussion Board
Re: 1066 WEIGHT
Posted by Harold H on February 14, 1999 at 16:04:56:
In Reply to: 1066 WEIGHT posted by LOUIE on February 14, 1999 at 06:23:25:
Louie,
The shipping weight of a Farmall 1066 with 11L-15 front and 18.4-38 rear tires was 11,861 lbs. This was the bare tractor with wide front axle, IPTO, and three point hitch. Be sure to add; weights, ROPS or cab, liquid in tires, and any mounted equipment your tractor may have.
Harold H
Post a Followup
: Re: Re: 1066 WEIGHT
